Istvan Agg, HA5CLF / N9EU
My favorite SOTA antenna is the End-Fed Half Wave Antenna. There are many good descriptions on the net about this type of antenna. I recommend a good reading on this subject by Steve Yates, AA5TB at: www.aa5tb.com/efha.html. However, let me write about it from a slightly different perspective that was not very obvious from the articles I read. This article will describe a 40/30/20m band end-fed half wave antenna, focusing on its matching unit. It will present its parameters, so anybody with basic home-brew skills will be able to build it. Nevertheless, I will also describe, how it is designed, if one decides to embark on building it for different bands.
Based on a 2014 survey, the most popular antennas for SOTA (Summit On The Air) activation are the following (see sotabeams.co.uk/blog/5-most-popular-hf-portable-antennas for details):
Antenna type |
% Of respondents surveyed |
1 |
End-Fed Half Wave |
18% |
2 |
Linked Dipole |
16% |
3 |
Single Band dipole |
12% |
4 |
Random Length End Fed wire |
12% |
5 |
Ground Plane Antenna |
11% |
Let us not confuse the End-Fed Half Wave antenna with the Random Length End Fed wire. That is an end-fed, but very different then the half wave construction. This article will not address that antenna type.
What are the advantages and disadvantages of the end-fed half wave antenna? I would mention first its ease of installation. Throw one end of the antenna wire, extended with a rope, as high as you can on a three, and walk away with the other end and attach it to the tuner. One end may even be close to the ground, not yielding the best radiation efficiency, but much activation proved it still operational. Of course, if both ends are raised higher, it will produce a more efficiently radiating antenna, but the portable and temporary installation is always compromised by conditions given by a location and its restrictions. Therefore, installation is quite easy, and its tuner circuit is rather simple as well. It does not need any special components; in fact, most of us may have them in our shack drawers already.
What are its disadvantages? I tried to operate from a hotel, and learned the hard way that this type of antenna is not suitable for such location. It requires a set distance to hang both ends of the antenna, and that is not always given. In an urban area we are much more restricted, especially if we need to be stealth about it.
So, how to construct an end-fed half wave antenna? Let us touch on some necessary theory to begin with.
In an ideal setting, the center of the antenna will have the lowest voltage, consequently impedance, which is why it is possible to feed it by 50 or 75Ω coaxial cable. We also know, that both ends of the half wave antenna will have the highest voltage, thus impedance, which may reach up to several kilo-ohms. This is why we need the impedance transformer from the 50Ω coaxial feed-line to the several kilo-ohm antenna connections. The impedance matching circuit is essentially a simple parallel resonant LC circuit. Select components with good insolating materials and properly chosen, relatively high voltage rated parts.
Essentially, the matching is done with a tank circuit, which represents the highest impedance when it is tuned to resonance. It matches the impedance fairly well to the half-wave antenna’s high impedance at one of its ends. There are two aspects, however that we need to consider:
- The impedance ratio of the transformer
- The tank circuit’s resonant frequency
Let’s begin with the transformer. We do not know what the actual impedance will be at the end of the antenna radiator. It may be one or even five kilo-ohms. It is best to make the impedance matching adjustable, using switched transformation ratio.
Because we are considering this tuner for SOTA activations or casual portable operation, we do not need to design it for more then 100W. Most of the time 5 to 20W will be adequate for activation anyway. For the transformer, a T130-2 toroid will be sufficient, on which we wind the seconder with multiple taps, as shown in the below table.
Tap number |
Primer turns |
Seconder turns |
Impedance output in kΩ |
Measured inductivity in μH |
1 |
2 |
10 |
1250 |
2.0 |
2 |
2 |
12 |
1800 |
2.3 |
3 |
2 |
14 |
2450 |
2.6 |
4 |
2 |
16 |
3200 |
3.0 |
5 |
2 |
18 |
4050 |
3.3 |
6 |
2 |
20 |
5000 |
3.6 |
Note: If we change the primary number of turns, the impedance ratios will considerable change also. If you need to change it, is necessary to recalculate the secondary turns, and the resonance frequency needs to be adjusted also. To calculate the impedance ratio, use the following equation:
Where:
Z ki / Output impedance
Z be / Input impedance, in this case 50Ω
N sec / Seconder number of turns
N prim / Primary number of turns
A completed tuner is shown here, which depicts the inductance assembly. The toroid with its many taps may be soldered directly on a multi-position switch.
The next important parameter is the parallel resonant circuit’s resonant frequency. It depends on the selection of the inductance and the capacitor values. It is important that resonance may be achieved at each tap of the inductance. We need to measure the inductances of the toroid with the tapped coil. The previous table already contains these measurements. These inductances are required in determining the right capacitance values, of which two values are important: the minimal and the maximum capacitance values.
We also need to know what are the frequencies or bands for which we plant to use this antenna. Assuming, most of us use the 40/30/20m band for HF SOTA activation, so the following table shows the SOTA frequencies, and the calculated half wave radiator wire of the antenna.
Band |
SOTA FRQ |
Mode |
λ/2 [m] |
40m |
7.032 |
CW |
20.22 |
30m |
10.118 |
CW |
14.05 |
20m |
14.285 |
SSB |
9.95 |
Consequently, let’s pick the lowest frequency 7,000MHz that we need to be able to tune the inductance to, for each of the taps on the inductance. The highest frequency could be14.350MHz.
Consequently, this is how the capacitance values are determined. Calculate the capacity for the resonance at the lowest frequency to be covered with the lowest inductivity taken in consideration. This will yield the maximum capacity of the variable capacitor.
Accordingly, calculate the capacity for the resonance at the highest frequency to be covered with the highest inductivity taken in consideration. This will yield the minimal capacitance of the variable capacitor.
Selecting the variable capacitor that can be varied from this minimum to maximum capacity, will allow tuning to resonance for 40, 30, and 20m bands at each of the switch position of the tuner. This will allow good matching of the half-wave radiating antenna wire to the 50Ω coaxial cable at virtually any location. It is not necessary to calculate the above; the results are sown in the following table.
Lowest frequency = 7.000 MHz |
Highest frequency = 14.350 MHz |
Lowest measured inductivity = 2.0 μH |
Highest measured inductivity = 3.6 μH |
Calculation result = 258 pF |
Calculation result = 34 pF |
In case you need to perform calculations, use the formula:
Where the frequency “f” is in MHz and the inductance “L” is in μH.
Finally the tank circuit’s specification is complete, which is sown below. The “Counterpoise” is a short, typically one twentieth (0.05 * λ) of the wavelength. From experience, I found that with this tuner my SWR was better by simply disconnecting the counterpoise at lower bands. It is worth experimenting with its length also.
It is important to consider the voltages on this tank circuit. At 5W input the connector at the end of the antenna wire may be up to 160V, and at 15W it may be 270V. Be cautious, such voltages may cause a quite painful skin scorch.
It is quite possible that designing more than three or four bands into a tuner will lead to a failure. It is quite difficult to satisfy both requirements of achieving proper impedance ratio and resonance of the tank circuit at each tap of the inductance. It is better to build one for 160 and 80m, perhaps add 17m to the design described in this article, and for higher bands it is easier to use a linked dipole.
I installed a QRP SWR meter into the tuner that makes tuning very handy. During portable operations, I noticed that I forgot the toggle switch in the tuning position, just to discover that no one calls me back to my relentless CQ-ing. Therefore, I picked a momentary push button to switch the operational mode to tuning mode while tuning up. With such a switch, it is impossible to forget to switch back to operational mode. See the second completed tuner depicted below. The disadvantage of this switch is that one needs one hand to hold it, another to key down, and yet another to tune the capacitor.
How does this SWR meter works? Tuning the antenna to its resonance will result in 50Ω seen at the output of the SWR circuit. That will be the missing “resistor” in the resistor bridge of the below circuit. The bridge than will measure zero voltage across the bridge, and the LED will turn off. If the antenna is not tuned properly, and it represents other than 50Ω, the diode will rectify the current flowing across the bridge and the LED will light up. It is recommended to use at least 2W non-inductive resistors for this purpose.
Another completed tuner, which is more compact then the pervious one shown, also it is lighter, more suitable for portable operations. Note that the primary winding on the toroid is using the inner lead of an RG-58 coaxial cable. This provides proper insulation from the relatively high voltages on the seconder winding.
I found it very useful to label the tuner with switch and capacitance positions. It is likely that next time the tuning may be set according to the already found positions, and it will not be far off, requiring only slight adjustment. Of course, you will need to find your tuning positions and apply your own position scale.
Band |
L |
C2 |
Counterpoise |
40m |
5 |
45 |
I did not need it |
30m |
5 |
75 |
I did not need it |
20m |
6 |
90 |
1m |
From this article one may build a 40, 30, 20m end fed half wave antenna, with no special parts needed, or no special skills required. The computation method is also touched on. There is much more that can be written about this antenna and its matching, but that was not my aim. My goal was to describe the parameters of an antenna that can be easily build, yet show enough theory for someone to design his or her own antenna and antenna tuner. I wish you lots of productive experimentations and successful portable operations.
Best 73!
HA5CLF / N9EU István
I have been searching the internet for a very long time (AA5TB, VK3YE, SOTA Reflector, among MANY others), and your posting finally made clear for me the many questions I have had.
As you stated early in your posting, I also have found 99.99% of all posting on the internet tell you WHAT they did….not HOW they determined the specific design criteria. Your posting put it all together for me…THANK YOU!!!!
I did struggle with the C in pF calculation…..I seem to be getting hung up on the correct decimal placement…..for example, for the 40-meter Capacitor requirement, I get .000000000258:
C pF = .000001 / [ ( 2 * 3.14 * 7 MHz) ^2 ] * 2 uH
= .000001 / 3868.88
= .00 00 00 00 0 258
= 258 * 10^-12
But I’ll find the error of my ways….and there are various on-line calculators to help me ensure I get the decimals and (H, mH, uH, pH, etc.) clear….
The bottomline, your putting the relationships of 1) Toroid windings and to measure their inductance together with 2) the required capacitance calculation is exactly what I needed to move forward with my specific design plans.
Hi Jim,
Thank you for your comment and feedback on the article about the EFHW antenna. As I reexamined my formula, you pointed it out correctly, there is an error in it. Your calculation is correct, the result I get is also .000000000258, which is clearly wrong (it is Farads instead of pF).
The equation should have a 10^6 and not 10^-6 in the nominator. I will go back and have the article corrected.
I designed and built a few EFHW tuners already (calculating them from scratch, I only “optimized” the formula for the article). I built one that you see in the article, another one that is much smaller and lighter for SOTA outings. I also built one that is heavy-duty handling easily up to 100W for 80/60/40m bands. And now I am planning to build one for 160/80m. This will also be handling 100W. It is fun to build them and measure the lower and upper frequency limits and to see how close the calculation was. I am planning to use this latest one at the Field Day next year.
We would like to try to fly a kite with a halfway antenna wire and see what “miracle” we achieve. If not a lightning strike, I will write an article about the experience as well.
Jim, do you mind if I add your email and my answer as a comment to the article? I also will ask, why didn’t it work for you.
Best regards and thanks again for your comment.
73 – Istvan ha5clf / n9eu
P.S.: I see you were able to post your comment now, so I just copied my email answer here for others to see.
The equation in the article is corrected now. Thanks again Jim.
Your article was well written and very informative, thanks. End-Fed antennas are useful in many ways, includes easier mounting of cable at one end (freeing the antenna from unnecessary weight of cable) & antenna maintenance in future.
Further if your antenna requires a biggeer counterpoise on some bands, you can increase the size of the radiating element or improve your Tuner by using fine tuning capacitor or altering the coils slightly by varying the coil windings (compressed/spread out) slightly. Be aware counterpoise or ground radials are required for all hf antennas for better performance. And not all hf antenna installation are same, with most requiring bit of tinkering.
Hi Ajai,
Thanks for your comments. Yes, indeed EFHW antennas are very useful for SOTA or other field operation. But I would caution its usage for higher power than 10-15W. Since the tuner’s location is best if it is handy for the operator, one end of the end-fed antenna is also close to the operator. The highest voltages as well as radiation are also at the end of the antenna wire. Even at 15W the voltage at the ends may reach 100-200V.
There is lot of controversy around the EFHW antennas. Some hams swear by them, yet some completely demean it.
So, I embarked on testing it for myself. I am currently working on measurements of an EFHW antenna. I am testing it with the tuned tank circuit and a coax to the tuner with and without a common mode rejection choke. And of course, a counterpoise with various lengths. I particularly want to know how counterpoise affects the common mode currents on the coax. Some say you do not need a counterpoise, but that is false. One way or another there is always a counterpoise involved if the antenna is tuned correctly. With no “counterpoise wire” it will be the coax’s shield providing it.
I am already seeing interesting things with it, but not enough measurements to make any conclusions yet. I will publish my findings, but I cannot not promise to complete it until early fall.
Best regards and 73,
Istvan
Hello, a wonderful approach for the problems..
i liked it a lot, you give good ideas, many thanks.
Can you give me an idea for your 100 W version, you built for 80/60/40 m.
Thanks in advance, good health for you in these times,
y73´s de Michael DL9SKY
Visszajelzés: The End-Fed Half Wave Antenna a bit Differently – Coventry Amateur Radio Society
Dear Istvan, Thank you very much for your nice description and explanations concerning the End Fed tuner. Now, I also would like to build my first End Fed tuner! I just have a question about the values of the measured inductivity. I have used two different calculation tools which give me an inductivity for example of 1.1 µH for 10 turns. You have the measured the double as value in your table. How can we explain this difference? Or made I something wrong ? Thank you. Best 73’s. Stephane.
